Who wants a 250-ton steam crane?
Re: Who wants a 250-ton steam crane?
Postby Hornbeam » Tue Aug 17, 2021 3:28 pm
If we give you a 'virtual' Chinese Burn :o will you let us into the Secret 8-) ?
Postby northeast » Tue Aug 17, 2021 4:00 pm
Maybe it's going 'upriver'. How far could it navigate in the Tyne, given its low draft and subject to any bridge restrictions.
Postby magoonigal » Tue Aug 17, 2021 5:04 pm
Well she is not going to get above Newcastle Quayside. At a very rough estimate her Air Draught is 100ft. Clearence under the Millennium Bridge is only 86ft and at 44ft beam she may also be to wide.
Postby Hornbeam » Tue Aug 17, 2021 6:25 pm
I will check that the Tees Pilots are on Standby shall I? ;)
Postby Whickham » Thu Aug 19, 2021 9:47 pm
I'd heard the last remaining Wallsend drydock, either to have the spare(?) structure removed or even the job broken up.
Postby northeast » Fri Aug 20, 2021 6:51 am
Seems like a long tow just to have her broken up.
Postby Hornbeam » Fri Aug 20, 2021 2:00 pm
Unfortunately I would guess that the idea and most probably the Sale of her was before Covid struck the World making such an idea non viable, best cut their losses and scrap her as I understand Scrap and indeed Rolex watches are showing good returns at the moment ;)
Postby creemaster » Sun Aug 22, 2021 8:48 am
Posts Facebook suggest she is in until 25th and then off to Holland for renovation which will last until 2025 and be berthed at Schiedam
Postby Hornbeam » Sun Aug 22, 2021 9:39 am
If the conversion goes ahead and as I have indicated previously the Dutch are very keen on preservation it will certainly looks to be an interesting outcome, I wonder if you will be able to order a cup of coffee and a spliff. :D
Postby northeast » Sun Aug 22, 2021 2:49 pm
creemaster wrote:Posts Facebook suggest she is in until 25th and then off to Holland for renovation which will last until 2025 and be berthed at Schiedam
So back to her birth-place, now that's starting to make sense ... but why not go there direct? Maybe she needs to fill out a truck full of EU import forms.
PreviousNext
