ESSO NORTHUMBRIA
ESSO NORTHUMBRIA
Postby MadMaxLab » Sun Jun 24, 2012 9:54 am
Launched by Swan's in 1969
Broken up at Kaohsing 1982
Leaving the Tyne 8/2/1970
Re: ESSO NORTHUMBRIA
Postby tynebuoy » Thu Nov 07, 2013 10:06 am
02.05.1969.
tynebuoy
Postby northeast » Thu Nov 07, 2013 12:10 pm
Wow, makes you realise how fast she approached the south bank!
Postby Whickham » Thu Nov 07, 2013 1:01 pm
Also just realised that they didn't have the big cranes on the berth then either. Wonder when they came into use?
Postby Dennis Maccoy » Thu Nov 07, 2013 3:40 pm
The 180 ton cranes were part of the redevelopment that included a new plate stockyard & treatment line behind the outfit quay, a new plate prep shop, a panel production line and a paint hall in Wallsend yard and a new section stockyard & treatment line at the head of the dry docks. Most of the buildings just visible behind No.5 berth (the down-river berth) were demolished to make room for the development. There was a plaque recording the official opening of the "Tyne Steelworking Facility" (TSF) on the wall in the panel line with a date of September 1971 (if my memory is still accurate!). I think that the 180 ton cranes were of a similar age.
Postby Whickham » Thu Nov 07, 2013 6:27 pm
Thanks Dennis, that would be about a year before I started at Wallsend.
Postby teesships » Thu Jan 16, 2014 2:07 pm
Two undated slides from Albert Weller showing her leaving the Tyne for trials or delivery:
Postby jmbrent » Mon Mar 30, 2015 9:34 pm
Hi, this was the first of the 8 super tankers built at Swans Wallsend yard, and she had some problems with her LP turbine whilst on sea trials, and in Lisbon the LP rotor had to be renewed which was quite a task but it proved it could be done and a lot of the cargo pump turbine exhaust pipe work had to be dismantled to retrieve LP turbine blades. The astern turbine blade became detached and it proved rather expensive foe AEI the turbine maker. Micky.
jmbrent
Postby teesships » Wed Jul 04, 2018 7:51 pm
ESSO NORTHUMBRIA (6917530), Esso Petroleum Co. Ltd., 126543gt, completed by Swan, Hunter - Wallsend-on-Tyne, 5-1970. 1982 broken up.
On the stocks and dwarfing the nearby housing.
I saw her while building on 20.7.1969.
Photo from TEESSHIPS archives, origin unknown, but contributed by Dave Martin:
Postby teesships » Sun Jul 21, 2019 7:59 pm
50 YEARS AGO
I photographed her River Tyne - 20 July 1969, but the negative has subsequently been "posted missing"!
Details of fate now clarified: BU Kaohsiung 7.5.82, work began 25.5.82 [Tai Yuan Steel Corp]
