Austin's Pontoon.
Austin's Pontoon.
Postby Stephen Swinhoe » Tue Aug 07, 2012 8:37 pm
Austin's Pontoon and the tug Lumley.
Stephen Swinhoe
Re: Austin's Pontoon.
Postby teesships » Tue Aug 07, 2012 9:20 pm
Postby Whickham » Tue Aug 07, 2012 9:38 pm
Cracking photo Steve. Anyone want a spare propeller, there's quite a few lying to the right of the dock.
Postby Whickham » Wed Aug 08, 2012 6:44 am
Steve has also pointed out something that I missed. The Pontoon is actually docking itself. The Pontoon is in two bits and one of them has been lifted out of the water by the other half. Routine maintenance I presume.
Postby teesships » Wed Aug 08, 2012 10:25 am
"Anyone want a spare propeller?" As I recall it seemed to be a particular feature of Sunderland Docks that there were spare propellers lying all around the dock estate - many more than I remember ever seeing in any other port.
Postby Whickham » Wed Aug 08, 2012 9:55 pm
I guess these propellers would be the spare cast iron jobs that were often bolted to the deck for use in emergencies. A bit like the space saver tyre in the modern car, will get you home but not much else. The props were probably too heavy to be "borrowed" and not worth enough for anyone to be really inventive about "borrowing" them to the local scrap yard.
Postby magoonigal » Wed Aug 08, 2012 10:12 pm
But is it Docking itself????
In all the pictures I've seen its only ever had one side and ships went on sideways.
Is the Second Structure just to keep the dock off the Quayside and keep it in Deep Water.
OR Looking at the other picture where it looks longer IS it docking its other half lenghtways???????????????
Postby northeast » Thu Aug 09, 2012 6:41 am
Yes Paul, just one sided and it is being docked lengthways on its 'other half'.
Postby magoonigal » Thu Aug 09, 2012 9:15 am
I must admit I had more or less worked that out before I finished the post having compared the length in this picture with the length in Dave's picture.
Does anyone know if the Wear had another floating dock at any time???
Postby Whickham » Thu Aug 09, 2012 10:20 am
Yes, I have seen photos by Stephen Swinhoe of one of the tugs (Alnwick I think) in a smaller floating dock. It was in the South Dock and in this case had "two sides".
Return to Shiprepairing on the Wear
