ADMINISTRATOR
ADMINISTRATOR
Postby Tony Frost » Wed Sep 24, 2014 2:17 pm
Tony Frost
Re: ADMINISTRATOR
Postby magoonigal » Fri Oct 03, 2014 9:46 am
William Doxford & Sons Ltd, Pallion Yard Number 826 in 1958 for the Ruthin SS Co. Ltd. Liverpool.
8,627 Gross. 11,455 Dwt. 15 knots.
Subsequent History:
78 TYNE - 78 ORIENTAL SEA
Disposal Data:
BU Chittagong 29.12.78 [Trans Overseas]
Re: ADMINISTRATOR
Postby teesships » Mon Jun 15, 2015 12:51 pm
50 YEARS AGO TODAY!
Middlesbrough Dock, 15 June 1965:
Re: ADMINISTRATOR
Postby teesships » Sat May 29, 2021 2:01 pm
New scan from original negative of view shown above
Middlesbrough Dock - 15 June 1965:
Re: ADMINISTRATOR
Postby creemaster » Tue Jun 01, 2021 6:15 pm
That's not the original 'super gun' on her main deck is it Ron? :)
Re: ADMINISTRATOR
Postby teesships » Tue Jun 01, 2021 8:26 pm
It then took 25 years to be discovered tucked away in a shed in Tees Dock!!
River Tees - ship anything, anywhere!!!
Re: ADMINISTRATOR
Postby Hornbeam » Tue Jun 01, 2021 10:07 pm
How true Teesships, fortunately the Customs were very alert in those days to spot that the pipe bore was machined a bit too smooth and precise for moving Oil, they did have other successes on the Import side with Pistols in Tranist from Eastern Europe for the IRA and the seizure of a Ton of Cannabis hidden in a bulk Guinness Flask which I witnessed on an Elder Dempster vessel along with a couple of Scousers 8-) who turned up with a Truck to take the Flask to Liverpool where the vessel had been diverted from.
Re: ADMINISTRATOR
Postby Hornbeam » Wed Jun 02, 2021 8:33 am
The Elder Dempster vessel concerned was the 'Sokoto' whose normal first Port of call after a trip to Africa was Liverpool, unfortunately for the Drugs Gang the Dockers were on strike and the vessel was diverted to Tees Dock. I was onboard during the operation when it all went pear shaped for the two Scouser's, there was a discussion in regards to letting them take what was now an empty Flask to see where the Flask would be taken to in the Liverpool area but it was decided that two jailbirds in the hand were better than an unknown number in the bush on this occasion.
Return to Doxford / Pallion
