ALBERTA
ALBERTA
Postby teesships » Sat Feb 19, 2022 6:15 pm
ALBERTA (8120741), Greece, 17882gt, completed Sunderland Shipbuilders, Pallion, Sundereland, 3-1984
1984 ALBEERTA -1993 NEA DOXA - 2002 DOXA D - BU Gadani Beach 10.4.13, beached 13.4.13 [SS Enterprises]
Fitting out at Sunderland - 26 February 1984:
Tees Dock - 28 July 1985:
Tees Dock - 5 October 1988:
From my negative collection, seen by Alan Sparrow earlier in the fitting-out process:
Re: ALBERTA
Postby fitter » Tue Sep 27, 2022 7:29 pm
The new building dock that was opened in 1986 very quickly proved inadequate. A vee shape had to be cut out at the fore end of the dock to allow the bigger ships to be built. On floating out, the ships were towed to J.L.Thompsons (North Sands yard) to have the rest of the fore end fitted and fitting out completed at Palmers Hill, hence the picture in the river with its fore peak missing. Palmers Hill was originally Dickenson's Engine works, (steam), that were taken over by Doxford engines for a while and where they built and tested the single cylinder Doxford P type engine that went to South Shields Marine & Tech before it was taken to the museum where it lives now. The former Dickensons and Doxford engine works can be seen behind the tower structure of the hammer head crane that was built at Laings. After Doxfords finished with the premises they were incorporated into Thompsons yard (by then part of the "Doxford and Sunderland Shipbuilding and Engineering Company," and were used as platers sheds and funnel building shops. Happy days and a nice memory
Return to Doxford / Pallion
