DANIO aground - news item
Re: DANIO aground - news item
Postby magoonigal » Thu Mar 28, 2013 11:35 pm
Part Three.
Postby magoonigal » Fri Mar 29, 2013 1:53 am
LOMAX made a brief stop on the Tyne before leaving just after midnight to head for Fawley.
Postby northeast » Fri Mar 29, 2013 7:29 am
Excellent coverage from 'our man in Blyth'!
Cheers, George
Postby magoonigal » Fri Mar 29, 2013 9:04 am
Still trying to warm up!
Postby tynebuoy » Fri Mar 29, 2013 9:46 am
Well done that man. The feeling starts to return after about 3 days.
tynebuoy
Postby downhill » Fri Mar 29, 2013 10:32 am
Great updates & pictures, thanks.
Are they sending divers down to check her hull in Blyth or will she have to dry-dock somewhere?
Cheers
Hendy
downhill
Postby magoonigal » Fri Mar 29, 2013 2:33 pm
Divers will go down at Blyth to inspect the hull for additional damage and then they will consider her future.
Postby Patrick Hill » Mon Apr 15, 2013 10:43 am
MCA detention report
Date and Place of detention: - 29 March 2013, Blyth Vessel Name: - DANIO (Multi Purpose General) GT: - 1499 IMONo: - 9218533 Flag: - Antigua & Barbuda Company: - CUXSHIP Management Classification Society: - Germanischer Lloyd (GL) Recognised Organisation: - Germanischer Lloyd (GL) Recognised Organisation for ISM: - Germanischer Lloyd (GL) Summary: - Fifteen deficiencies including seven grounds for detention
The vessel was detained in Blyth as there was a lack of familiarity and training regarding the bridge operation along with the voyage passage plan not be as required; navigation records were not kept up to date and the manning specified by the minimum safe manning document were not as required and nine deficiencies were marked as ISM, which demonstrate there was objective evidence of a serious failure, or lack of effectiveness of the implementation of the ISM Code. Other deficiencies identified as vessel damaged after grounding included the hull and ballast tank were holed, the propeller and rudders were also damaged. The magnetic compass was not readable from conning position. The TV in the wheelhouse is to be removed. Records of rest and cargo ship safety equipment certificate were not found as expected. The vessel was still detained at 31 March 2013
Postby magoonigal » Mon Apr 15, 2013 5:45 pm
Couple of pictures of the Danio at Number 37 Jetty, Blyth.
30th March.
6th April.
Looking at the initial Report one is tempted to read betwwen the Lines as most of us will have done.......
Postby creemaster » Mon Apr 15, 2013 9:14 pm
Looks like BHC/Port of Blyth had good reason for sticking her out of the way at 37 Jetty. Wonder how long she will be here for. Not as long as the floating crane which demolished the old West Blyth Staithes I hope.
PreviousNext
