Giulio Verne
Giulio Verne
Postby creemaster » Tue May 08, 2018 5:36 pm
Cable ship which turned up yesterday and was working close inshore yesterday afternoon. Today she is way off in the distance.
Her blurb is...........
Giulio Verne is a DP2 cable laying vessel built for most challenging worldwide subsea operations. With its 7,000 tons carousel capacity, the vessel is equipped to conduct deepest power cable lay up to 1,600m water depth. The primary function of the vessel is the execution of challenging power cable installation projects. However it can also be used on any kind of subsea and offshore project – from shallow to deep water - for which she is ideally suited and equipped. She holds an extensive track record, on a variety of diverse subsea construction projects and she is well known in the market as a reliable and robust unit, capable of handling harsh environmental conditions. .
never believe what you read. It's Cambois not Blyth
Re: giulio verne
Postby teesships » Tue May 08, 2018 6:19 pm
As ITM VENTURER see also viewtopic.php?f=43&t=11351
R.
Re: Giulio Verne
Postby creemaster » Fri Sep 21, 2018 1:50 pm
And now hitching a ride on DOCKWISE's BLACK MARLIN from Rotterdam to Singapore
http://www.shipspotting.com/gallery/pho ... id=2913243
Return to Blyth
