ELLA F
ELLA F
Postby creemaster » Thu Aug 23, 2018 6:39 pm
Small Dutch work boat ELLA F approaching the port from doing survey work off the River Wansbeck in support of the operations to lay the leccie cable from Norway to Cambois.
regards
Re: ELLA F
Postby TEESMAN » Thu Aug 23, 2018 6:56 pm
Re: ELLA F
Postby magoonigal » Thu Aug 23, 2018 9:24 pm
SMALL??????
Ella F
Neptune 35m Ultra Shallow Draft DpII MPSV
Ella F is a revolutionary new evolution in
workboat design, the concept delivers a
vessel with the power of a tug, the versatility
of a shoalbuster, and yet she is still able to
operate in the shallow water that is normally
reserved for small multicats. A truly unique
and ground breaking concept. Ella F is also an
ideal option for Survey work and or UXO
Clearance
Built in the Netherlands at Aalst in 2017 for GSS Marine Services of Silverhills, Rosneath, Argyll & Bute.
496 Gross. Length 117ft. Beam 50ft. Bollard Pull 31 tonnes.
She has facilities for 21 Persons, fresh water making equipment, a sewage plant and on board Hospital.
Return to Blyth
